はじめに
The power supply keeps the TiVo fully functioning with power. if some component is bent or needs replacement then the supply may need to be fixed; here is how to replace the power supply.
必要な工具と部品
Remove the 140 mm T8 screw from the back of the TiVo premiere XL4 box holding the power supply in place using a Torx screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
