はじめに
The power supply keeps the TiVo fully functioning with power. if some component is bent or needs replacement then the supply may need to be fixed; here is how to replace the power supply.
  1. Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver. Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove the 140 mm T8 screw from the back of the TiVo premiere XL4 box holding the power supply in place using a Torx screwdriver.
    • Remove the 140 mm T8 screw from the back of the TiVo premiere XL4 box holding the power supply in place using a Torx screwdriver.
  6. Remove the two 80 mm T10 screws from the power supply using a Torx screwdriver.
    • Remove the two 80 mm T10 screws from the power supply using a Torx screwdriver.
  7. Remove the power cable from the motherboard by gently pinching the connector.
    • Remove the power cable from the motherboard by gently pinching the connector.
  8. Pinch the two plastic plugs and lift the power supply to detach the plugs from the board.
    • Pinch the two plastic plugs and lift the power supply to detach the plugs from the board.
  9. Take out the power supply unit.
    • Take out the power supply unit.
まとめ
Frances Prewitt
メンバー登録日: 2018年10月22日
637 ポイント
5のガイドは作成済み
チーム
Baylor, Team S1-G1, Williams Fall 2018 Baylor, Team S1-G1, Williams Fall 2018人のメンバー
BU-WILLIAMS-F18S1G1
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 51
