Using pliers, be sure that the cable jack is centered with the back of the box for easy removal.
This step above is only necessary if it is not aligned.
Remove the nut on the cable jack using pliers.
Remove the washer after removing the nut.
Pinch the connector of the bundle of wires (the bundle having black, red, black and yellow wires) and gently remove from the motherboard.
Pinch the connector of the single flat red wire and gently remove from motherboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
