メインコンテンツにスキップ
TiVo Premiere XL4 Motherboard Replacement
必要な工具と部品
  1. TiVo Premiere XL4 Motherboard Replacement, Case: 手順 1、 1の画像 1
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Motherboard Replacement: 手順 2、 2の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Motherboard Replacement: 手順 3、 1の画像 1
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
  4. TiVo Premiere XL4 Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    • Remove the single 140 mm T8 screw from the back panel using a Torx screwdriver.
  5. TiVo Premiere XL4 Motherboard Replacement: 手順 5、 2の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 5、 2の画像 2
    • Unplug the wire of the fan by gently squeezing the connector and lifting up.
  6. TiVo Premiere XL4 Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the power supply wire by pinching the plastic connection and gently pulling away from the motherboard.
  7. TiVo Premiere XL4 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the single 80 mm T10 screw above HDMI port using the Torx screwdriver.
  8. TiVo Premiere XL4 Motherboard Replacement: 手順 8、 1の画像 1
    • Remove wire connected to the front of of the box by pinching the connector and gently removing from the motherboard.
  9. TiVo Premiere XL4 Motherboard Replacement: 手順 9、 2の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove two 100 mm T10 screws connecting the front cover to the hardware of the box using a Torx screwdriver.
    • Unplug the connector from the front panel.
  10. TiVo Premiere XL4 Motherboard Replacement: 手順 10、 1の画像 1
    • Remove the front of the TiVo.
    • This step helps with the process of removing the motherboard due to the plastic prongs putting pressure on the board.
  11. TiVo Premiere XL4 Motherboard Replacement: 手順 11、 1の画像 1
    • Using pliers, be sure that the cable jack is centered with the back of the box for easy removal.
    • This step above is only necessary if it is not aligned.
    • Remove the nut on the cable jack using pliers.
    • Remove the washer after removing the nut.
  12. TiVo Premiere XL4 Motherboard Replacement: 手順 12、 3の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 12、 3の画像 2 TiVo Premiere XL4 Motherboard Replacement: 手順 12、 3の画像 3
    • Remove the following (2) 80 mm T10 screws including the (2) 80 mm T10 screws located on the other side using the Torx Screwdriver.
    • Remove hard drive from on top of the motherboard.
  13. TiVo Premiere XL4 Motherboard Replacement: 手順 13、 3の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 13、 3の画像 2 TiVo Premiere XL4 Motherboard Replacement: 手順 13、 3の画像 3
    • Pinch the connector of the bundle of wires (the bundle having black, red, black and yellow wires) and gently remove from the motherboard.
    • Pinch the connector of the single flat red wire and gently remove from motherboard.
  14. TiVo Premiere XL4 Motherboard Replacement: 手順 14、 2の画像 1 TiVo Premiere XL4 Motherboard Replacement: 手順 14、 2の画像 2
    • Remove the two 200 mm screws holding the motherboard in place to the bottom of the box using pliers.
  15. TiVo Premiere XL4 Motherboard Replacement: 手順 15、 1の画像 1
    • Remove the six 80 mm T10 screws using the Torx Screwdriver.
  16. TiVo Premiere XL4 Motherboard Replacement: 手順 16、 1の画像 1
    • Remove the motherboard from the box.
終わりに
作成者
3人の作成者と共同で作成されました。
Frances Prewitt
メンバー登録日: 10/22/18
661 ポイント
6のガイドは作成済み
チーム
Baylor, Team S1-G1, Williams Fall 2018 Baylor, Team S1-G1, Williams Fall 2018人のメンバー
BU-WILLIAMS-F18S1G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 530
