メインコンテンツにスキップ
Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
必要な工具と部品
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: 手順 2、 2の画像 1 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: 手順 2、 2の画像 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: 手順 3、 1の画像 1
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mohammed Alsogair
メンバー登録日: 10/18/17
339 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G33
4 メンバー
5のガイドは作成済み
3 件のコメント
how can I replace elastic cord?
geoff - 返信
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - 返信
Where did you get a replacement motherboard?
Paul Stewart - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 122
今までの合計 5,319
