メインコンテンツにスキップ
Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement
必要な工具と部品
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 手順 2、 2の画像 1 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 手順 2、 2の画像 2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 手順 3、 2の画像 1 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 手順 3、 2の画像 2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Mario Nunez
メンバー登録日: 10/18/17
421 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S1G33
4 メンバー
5のガイドは作成済み
2 件のコメント
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - 返信
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 40
今までの合計 5,465
