メインコンテンツにスキップ
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
必要な工具と部品
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: 手順 1、 1の画像 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 手順 2、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 手順 2、 2の画像 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 手順 3、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 手順 3、 2の画像 2
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 4、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 4、 2の画像 2
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 5、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 5、 2の画像 2
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 6、 1の画像 1
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 7、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 7、 2の画像 2
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 8、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 8、 2の画像 2
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 9、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 9、 2の画像 2
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 10、 2の画像 1 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 10、 2の画像 2
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 11、 1の画像 1
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 手順 12、 1の画像 1
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
終わりに
作成者
2人の作成者と共同で作成されました。
Aaron Banaga
メンバー登録日: 09/11/17
526 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G1
3 メンバー
13のガイドは作成済み
コメント 1 件
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 1,578
