メインコンテンツにスキップ
Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement
必要な工具と部品
  1. Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: 手順 1、 2の画像 1 Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: 手順 1、 2の画像 2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Aaron Banaga
メンバー登録日: 09/11/17
526 ポイント
4のガイドは作成済み
チーム
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S2G1
3 メンバー
13のガイドは作成済み
4 件のコメント
there are small plastic pieces in mine, when i took it off now my joystick wont work or turn properly and I havent found any guide to where these pieces go??
beardy1 - 返信
I'm wondering the same thing right now. That round spring with the arms on it and the black lC shaped plastic piece.
Brent Taylor-Wooster -
On the bottom of the stick assembly you will see a small slot head screw like indent. That is a built in manual stop, rotate 45 to 90 degrees in the loosening direction, it will un lock
Edit: I was trying to include 3 pictures of the assembly and install but no luck sorry
Timothy Brake -
I found this link which shows where that black plastic piece goes: https://channellfd.com/t-flight-hotas-x-...
You know how there are three holes on the bottom of the stick, but only two screws? It goes in the third hole.
HolleringHuskarl -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 30
今までの合計 3,875
