はじめに
You don’t need a sewing machine to sew. But a machine can save you a lot of time when you make repairs, so if you have access to a sewing machine, here’s how to thread it. In this guide we’re using a Bernina 830, but the process will be similar for most sewing machines. Refer to your sewing machine’s owner’s manual for specific directions on how to thread the machine.
必要な工具と部品
Place a spool on the pin. Pull the thread from the spool straight out, following the length of the machine.
Hook the thread under the eyelet on the outer edge of the machine.
With one hand, hold the spool steady. Using the eyelet as a pivot, pull the string perpendicular with the other hand. Lay the thread into the slot, which bisects the top of the machine.
Pull the thread all the way across the slot on the top of the sewing machine. Then, pull the thread down toward the presser foot.
There is a lever just above the presser foot. Hook the thread under the lever until it rests in the crux.
Pull the thread back up toward the top of the machine.
At the top of the machine, lead the thread along the groove of the take-up lever.
Once you've fed the thread into the crux of the take-up lever, pull the thread back down towards the presser foot.
While continuing to hold the top thread advance the sewing machine with the balance wheel (also know as the hand wheel), to pick up the bobbin thread.
Grasp these two threads between pinched fingers and pull them in unison toward the body of the machine, leaving two to three inch tails.
10 の人々がこのガイドを完成させました。
9 件のコメント
Sewing machine comparison and reviews
Detailed and straight to the point comparison and product reviews of sewing machines. Insights on features, performance and best buying practices.
Best Sewing Review is here to help you what you need to know about in sewing . Check here https://bestsewingreview.com
A good site to get knowledge about the <a href="http://www.buysewingmachineguide.com/"> sewing machine. </a>
is it possible to add some videos on the site it will be very helpful for us to follow this as I am also sharing my knowledge here https://topsewingmachinereviews.com/
How do u thread a sewmor model 202?
Want to learn about sewing machines and sewing? Checkout of sewing machine site
Suggest for all about lol beans
zoano zozo - 返信
This was SO helpful and informative. I’m probably at an intermediate skill level, and almost everything you said was useful and new info for me.
