メインコンテンツにスキップ
Thread a Sewing Machine
必要な工具と部品
  1. Thread a Sewing Machine, Thread a Sewing Machine: 手順 1、 3の画像 1 Thread a Sewing Machine, Thread a Sewing Machine: 手順 1、 3の画像 2 Thread a Sewing Machine, Thread a Sewing Machine: 手順 1、 3の画像 3
    • Place a spool on the pin. Pull the thread from the spool straight out, following the length of the machine.
    • Hook the thread under the eyelet on the outer edge of the machine.
    • With one hand, hold the spool steady. Using the eyelet as a pivot, pull the string perpendicular with the other hand. Lay the thread into the slot, which bisects the top of the machine.
  2. Thread a Sewing Machine: 手順 2、 3の画像 1 Thread a Sewing Machine: 手順 2、 3の画像 2 Thread a Sewing Machine: 手順 2、 3の画像 3
    • Pull the thread all the way across the slot on the top of the sewing machine. Then, pull the thread down toward the presser foot.
    • There is a lever just above the presser foot. Hook the thread under the lever until it rests in the crux.
    • Pull the thread back up toward the top of the machine.
  3. Thread a Sewing Machine: 手順 3、 3の画像 1 Thread a Sewing Machine: 手順 3、 3の画像 2 Thread a Sewing Machine: 手順 3、 3の画像 3
    • At the top of the machine, lead the thread along the groove of the take-up lever.
    • Once you've fed the thread into the crux of the take-up lever, pull the thread back down towards the presser foot.
    • If you've threaded correctly, your thread should form a complete zigzag—first down, then up, then back down all the way to the presser foot.
  4. Thread a Sewing Machine: 手順 4、 2の画像 1 Thread a Sewing Machine: 手順 4、 2の画像 2
    • Hook the thread behind the small, bent arm where the needle attaches to the machine.
    • Guide the thread, from front to back, through the eye of the needle, leaving a loose end of approximately 10 cm.
    • If the end of your thread has frayed and you cannot guide it through the eye of the needle, snip off the frayed end and try again.
  5. Thread a Sewing Machine: 手順 5、 2の画像 1 Thread a Sewing Machine: 手順 5、 2の画像 2
    • After you've guided the thread through the eye of the needle, pull the thread down and through the large groove in the presser foot.
    • Hook the thread along the groove and pull it perpendicular toward the body of the machine.
  6. Thread a Sewing Machine: 手順 6、 3の画像 1 Thread a Sewing Machine: 手順 6、 3の画像 2 Thread a Sewing Machine: 手順 6、 3の画像 3
    • While continuing to hold the top thread advance the sewing machine with the balance wheel (also know as the hand wheel), to pick up the bobbin thread.
    • Only turn the balance wheel in the direction that advances the machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
    • Grasp these two threads between pinched fingers and pull them in unison toward the body of the machine, leaving two to three inch tails.
  7. Thread a Sewing Machine: 手順 7、 2の画像 1 Thread a Sewing Machine: 手順 7、 2の画像 2
    • Slide the sewing machine table onto the machine.
    • Hold the sewing machine table so that is lays flush with the sewing machine.
  8. Thread a Sewing Machine: 手順 8、 2の画像 1 Thread a Sewing Machine: 手順 8、 2の画像 2
    • Lock the sewing machine table into place by pushing the clamp lever to the right until it engages.
ゴール
10 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,014 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
9 件のコメント
Sewing machine comparison and reviews
Detailed and straight to the point comparison and product reviews of sewing machines. Insights on features, performance and best buying practices.
https://www.comparencart.com
cart - 返信
Sewing machine reviews
Best Sewing Review is here to help you what you need to know about in sewing . Check here https://bestsewingreview.com
Daisy - 返信
A good site to get knowledge about the <a href="http://www.buysewingmachineguide.com/"> sewing machine. </a>
sewing machne - 返信
is it possible to add some videos on the site it will be very helpful for us to follow this as I am also sharing my knowledge here https://topsewingmachinereviews.com/
Md.Harun Rashid - 返信
How do u thread a sewmor model 202?
Helen jennings - 返信
Want to learn about sewing machines and sewing? Checkout of sewing machine site
brainmiller - 返信
Suggest for all about lol beans
zoano zozo - 返信
wooow Brittany McCrigler the steps on how to thread a sewing machine are awesome. Trouble some when its time to fix the thread through the needle my eyes are kaput even at times when my glasses are on finally with enough struggle i have to fix it in order to complete a garment thanks
dani - 返信
This was SO helpful and informative. I’m probably at an intermediate skill level, and almost everything you said was useful and new info for me.
dani - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 50
過去 30 日: 278
今までの合計 21,226
