メインコンテンツにスキップ
Thomas Ride On Train battery replacement
必要な工具と部品
  1. Thomas Ride On Train battery replacement, Open the seat: 手順 1、 1の画像 1
    • Remove the seat by unscrewing the single screw located just by the backrest
    • Slide the seat backwards to unclip it
    • Unscrew the battery restraint
    • If you are replacing with an official replacement then it's a simple case of unclipping the old battery.
    • Alternative battery
    • If however you are swapping in an alternatively sourced battery you will need to cut off that clip.
    • The condition of the battery can most easily be told by charging it and seeing how much use you get out of it before it needs recharging again.
    • However if you have a multimeter then you can also look at the voltage of the battery.
    • Details of checking the battery
  2. Thomas Ride On Train battery replacement, Replacing the new battery: 手順 4、 1の画像 1
    • If you are using a official replacement battery this again should be a simple case of clipping the new one in place.
    • Finish up by replacing the restraining clip making sure to avoid trapping any wires. Replace the seat up by sliding it firmly forwards then screwing down
    • Crimp or solder on suitable connectors for the new battery ensuring that the red and black wires are connected to the same connectors on the battery.
    • It is a good idea to ensure that the battery can disconnected for future diagnosis, external charging or replacement
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Andy from Workshopshed
メンバー登録日: 05/21/13
420 ポイント
3のガイドは作成済み
6 件のコメント
Hi,
I need a new battery 6v for Thomas ride on train.
Can you pls recommend a brand? Or can I use 12v instead ? Thanks
kowalska.sa - 返信
Can I use 2 6v battery's to make this train go faster??
Reggie - 返信
If you use a 12v or two 6v attached in series it could damage the sound board.
Two 6v in parallel would give you a longer run the between charges.
Andy from Workshopshed - 返信
The official battery is 6v 4Ah, check the dimensions against the battery compartment or old battery
http://www.hedstrom.co.uk/shop/spares/th...
When replacing battery on the train the negative wire came off a little silver rectangular piece hooked to it what is this part and do I need it or can I bypass it
Leonard Breyne - 返信
Hey Leonard, are you talking about “spade connectors" ? It's a good idea to have the battery so that it can be quickly disconnected, soldering the wires to the battery would be a bad idea
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 79
今までの合計 14,465
