メインコンテンツにスキップ
ThinkPad Yoga 12 Battery Replacement
必要な工具と部品
  1. ThinkPad Yoga 12 Battery Replacement, Screws: 手順 1、 3の画像 1 ThinkPad Yoga 12 Battery Replacement, Screws: 手順 1、 3の画像 2 ThinkPad Yoga 12 Battery Replacement, Screws: 手順 1、 3の画像 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
    Ten screws, but who’s counting. Thank you!
    jthrall - 返信
  2. ThinkPad Yoga 12 Battery Replacement, Prying: 手順 2、 2の画像 1 ThinkPad Yoga 12 Battery Replacement, Prying: 手順 2、 2の画像 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: 手順 3、 1の画像 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: 手順 4、 2の画像 1 ThinkPad Yoga 12 Battery Replacement, Removing the screw: 手順 4、 2の画像 2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: 手順 5、 2の画像 1 ThinkPad Yoga 12 Battery Replacement, Lift: 手順 5、 2の画像 2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: 手順 6、 3の画像 1 ThinkPad Yoga 12 Battery Replacement, Connecter: 手順 6、 3の画像 2 ThinkPad Yoga 12 Battery Replacement, Connecter: 手順 6、 3の画像 3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
[deleted]
メンバー登録日: 03/18/18
1,324 ポイント
3のガイドは作成済み
コメント 1 件
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 6,522
