メインコンテンツにスキップ
ThinkPad X1 Carbon SSD Replacement
必要な工具と部品
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 手順 1、 1の画像 1
    • Use phillips #2 screwdriver to loosen seven cover screws.
    Don’t forget to backup your data
    Oliver - 返信
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 手順 2、 1の画像 1
    • Use spudger to pop open bottom cover, remove and set aside.
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: 手順 3、 1の画像 1
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: 手順 4、 1の画像 1
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: 手順 5、 1の画像 1
    • Remove the SSD by sliding it out of the connector to the right.
終わりに
11 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Mike
メンバー登録日: 06/23/16
1,834 ポイント
5のガイドは作成済み
チーム
iReconstruction iReconstruction人のメンバー
Business
1 メンバー
11のガイドは作成済み
7 件のコメント
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - 返信
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - 返信
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - 返信
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - 返信
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau -
Can someone confirm the m.2 type on these units?
Thomas Keats - 返信
Is anyone aware (before I take mine apart) of whether or not a Gen 7 can accommodate a M.2 SSD fitted with a heatsink? Thanks.
Nhonz - 返信
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 125
過去 30 日: 509
今までの合計 42,816
