メインコンテンツにスキップ
ThinkPad X1 Carbon Fan Replacement
必要な工具と部品
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: 手順 1、 1の画像 1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: 手順 2、 1の画像 1
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: 手順 3、 1の画像 1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: 手順 5、 1の画像 1
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
    Hi! Does anybody know where to get the little black clip that fixes the fan cable to the connector? Unfortunately I broke it when I removed the fan. Any other suggestions on how to fix the cable are appreciated.
    Jupp NN - 返信
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: 手順 6、 1の画像 1
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
    Which generation X1 Carbon is this? I have a 1st Gen and a 5th Gen, neither match this layout. Please updated with the Generation in the title. Thank you.
    Stanislav Valov - 返信
終わりに
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mike
メンバー登録日: 06/23/16
1,834 ポイント
5のガイドは作成済み
チーム
iReconstruction iReconstruction人のメンバー
Business
1 メンバー
11のガイドは作成済み
コメント 1 件
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 30
過去 30 日: 113
今までの合計 12,583
