メインコンテンツにスキップ
ThinkPad X1 Carbon 1st Gen Fan Replacement
必要な工具と部品
  1. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove rear screws: 手順 1、 1の画像 1
    • Turn the laptop upside down, with the screen hinge away from you. Using the 0 size Phillips screwdriver, remove the 7 screws.
  2. ThinkPad X1 Carbon 1st Gen Fan Replacement, Open keyboard: 手順 2、 1の画像 1
    • Turn the laptop right side up, and open the screen. Slide the plastic the spudger along the edge of the device to separate the keyboard tray. There are 4 catches, two on the top and two on the bottom.
  3. ThinkPad X1 Carbon 1st Gen Fan Replacement, Open keyboard: 手順 3、 1の画像 1
    • Gently lift the keyboard away from you, as you would open the screen. The cable connecting the keyboard to the chassis is at the top. It will want to shift slightly to the right as you open it to account for the cable.
  4. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove keyboard: 手順 4、 1の画像 1
    • Gently pry away the keyboard connector from the chassis, and set the keyboard aside.
  5. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove CPU fan screws: 手順 5、 1の画像 1
    • Locate the fan on the left side of the exposed device.
    • Remove the 4 screws using the 00 size Phillips screwdriver, in the order detailed on the CPU, starting at the top left.
    • Next, the CPU fan cable, circled in red...
  6. ThinkPad X1 Carbon 1st Gen Fan Replacement, Remove CPU fan cable: 手順 6、 1の画像 1
    • Gently lift the CPU fan cable socket latch, and pull the cable to the left to remove.
  7. ThinkPad X1 Carbon 1st Gen Fan Replacement, Clean socket, CPU: 手順 7、 2の画像 1 ThinkPad X1 Carbon 1st Gen Fan Replacement, Clean socket, CPU: 手順 7、 2の画像 2
    • Clean the CPU with isopropyl alcohol, and the dust catcher for any debris/dust.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Kirby Raines
メンバー登録日: 01/23/18
648 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team S1-G3, Virtue Spring 2018 Western Carolina University, Team S1-G3, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 24
今までの合計 2,133
