メインコンテンツにスキップ
ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement
必要な工具と部品
  1. ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement, Loosen Cover Screws: 手順 1、 1の画像 1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement, Remove Cover: 手順 2、 1の画像 1
    • Use spudger to pop loose cover and slide off.
  3. ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement, Disconnect Battery: 手順 3、 1の画像 1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove five screws holding battery in place and remove battery.
  4. ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement, RTC battery replacement: 手順 4、 1の画像 1
    • Firstly go through separate battery removal guide. insert straightend paper clip into SIM card holder (arrow) and eject and remove it.
    • remove 8 screws shown, incl, metal plate over charging connector and the sim card holder.
    • Wireless LAN RF cables can be left in place.
    • disconnect all other connectors from mainboard (and tape that fixes the connectors and Flex connectors)
    • Tip : Take note of magnet location (square) and orientation in case it dislodges. use marker if needed.
  5. ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement: 手順 5、 2の画像 1 ThinkPad X1 Carbon (3rd Gen) RTC Battery Replacement: 手順 5、 2の画像 2
    • Pry up main board gently by lifting the Fan end of the motherboard.
    • pull board gently toward the fan end to dislodge the connectors from the case and release the main board.
    • when released, turn over the board to view backside of mainboard.
    • RTC battery can now be replaced.
    • Functional RTC voltage is above 3,1V.
    • Brand new RTC voltage is 3,3V
    • recommend to tape down loose connectors away from main board while assembling the main board.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Carsten Dahl Hjarup
メンバー登録日: 11/04/13
2,796 ポイント
8のガイドは作成済み
コメント 1 件
Great guide. Thank you Carsten! Might I suggest a small correction to the grammar in the intro? The first paragraph would be better written as
"If the computer cannot retain date and time, and gives an error on bootup, then the Real Time Clock battery needs replacement. This guide shows how to perform RTC battery replacement.
The RTC battery is located at the bottom of the mainboard, which will need to be lifted out before the RTC battery can be replaced."
davidhollway - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 88
過去 30 日: 355
今までの合計 4,583
