メインコンテンツにスキップ
ThinkPad T420 Keyboard Replacement
必要な工具と部品
  1. ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: 手順 1、 3の画像 1 ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: 手順 1、 3の画像 2 ThinkPad T420 Keyboard Replacement, Find your keyboard FRU: 手順 1、 3の画像 3
    • Each country has a different keyboard FRU part number. Refer to the guide photos or the Lenovo HMM if you live outside of the US.
    • The old part can also be used as a reference.
  2. ThinkPad T420 Keyboard Replacement, Remove the battery: 手順 2、 3の画像 1 ThinkPad T420 Keyboard Replacement, Remove the battery: 手順 2、 3の画像 2 ThinkPad T420 Keyboard Replacement, Remove the battery: 手順 2、 3の画像 3
    • Remove the battery. Push the locking tab to the unlocked position.
    • Once the battery is unlocked, hold the battery release tab in and pull the battery out.
  3. ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 3、 3の画像 1 ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 3、 3の画像 2 ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 3、 3の画像 3
    • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
    • To remove the RAM door, use a Phillips #0 bit. Unscrew the RAM door and set the screw aside in a safe location.
    • To remove the RAM door, pull it off from the side. This can be done with a plastic pry tool or your fingernail.
  4. ThinkPad T420 Keyboard Replacement, Remove the keyboard screw: 手順 4、 2の画像 1 ThinkPad T420 Keyboard Replacement, Remove the keyboard screw: 手順 4、 2の画像 2
    • A magnetic screwdriver is highly recommended. This screw has a tendency to not come out unless a magnet is used.
    • To remove the keyboard, remove the final screw. This will be located under the RAM door.
  5. ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 5、 3の画像 1 ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 5、 3の画像 2 ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 5、 3の画像 3
    • Open the laptop.
    • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
    • Once the keyboard is loose, remove it from the chassis.
  6. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 6、 3の画像 1 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 6、 3の画像 2 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 6、 3の画像 3
    • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
    • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
  7. ThinkPad T420 Keyboard Replacement, Keyboard re-installation: 手順 7、 3の画像 1 ThinkPad T420 Keyboard Replacement, Keyboard re-installation: 手順 7、 3の画像 2 ThinkPad T420 Keyboard Replacement, Keyboard re-installation: 手順 7、 3の画像 3
    • Reconnect the keyboard to the motherboard. Once connected, slide the top (volume controls) in first.
    • Once the top of the keyboard is pushed in, slide the keyboard down to re-engage the lower clips until they are not visible.
    • Replace the silver screw and RAM door.
ゴール
7 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
88,911 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,541のガイドは作成済み
3 件のコメント
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - 返信
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - 返信
I love how simply disassemby are in those old ThinkPads <3
Ziobro - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 17
過去 30 日: 130
今までの合計 11,884
