メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ThinkPad T420 Keyboard Replacement
必要な工具と部品
    1. ThinkPad T420 Keyboard Replacement, Change note: 手順 1、 2の画像 1 ThinkPad T420 Keyboard Replacement, Change note: 手順 1、 2の画像 2
      この手順で使用する道具:
      Essential Electronics Toolkit
      $29.95
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      FixBotに聞いてみる
      コメントを追加
    1. ThinkPad T420 Keyboard Replacement, Keyboard FRU: 手順 2、 1の画像 1
      • If the label on the back of the keyboard is not worn, that can be used to reference which keyboard is needed.
      • IMPORTANT: Each country has a different keyboard FRU part number. To match the keyboard you have and which one you need to purchase, check the back label or refer to the Lenovo HMM.
      FixBotに聞いてみる
      コメントを追加
    1. ThinkPad T420 Keyboard Replacement, Unlock the battery: 手順 3、 3の画像 1 ThinkPad T420 Keyboard Replacement, Unlock the battery: 手順 3、 3の画像 2 ThinkPad T420 Keyboard Replacement, Unlock the battery: 手順 3、 3の画像 3
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
      FixBotに聞いてみる
      コメントを追加
    2. ThinkPad T420 Keyboard Replacement, Release the battery: 手順 4、 3の画像 1 ThinkPad T420 Keyboard Replacement, Release the battery: 手順 4、 3の画像 2 ThinkPad T420 Keyboard Replacement, Release the battery: 手順 4、 3の画像 3
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
      FixBotに聞いてみる
      コメントを追加
    1. ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 5、 3の画像 1 ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 5、 3の画像 2 ThinkPad T420 Keyboard Replacement, Remove the RAM door: 手順 5、 3の画像 3
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
      FixBotに聞いてみる
      コメントを追加
    2. ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 6、 3の画像 1 ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 6、 3の画像 2 ThinkPad T420 Keyboard Replacement, Remove the keyboard: 手順 6、 3の画像 3
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
      FixBotに聞いてみる
      コメントを追加
    3. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 7、 3の画像 1 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 7、 3の画像 2 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: 手順 7、 3の画像 3
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
105,359 ポイント
72のガイドは作成済み
3件のガイドコメント
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - 返信 共有
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - 返信 共有
I love how simply disassemby are in those old ThinkPads <3
Ziobro - 返信 共有
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 46
過去 30 日: 189
今までの合計 16,169
