メインコンテンツにスキップ
ThinkPad T420 Keyboard Replacement
必要な工具と部品
    • 1.For access, remove these FRUs in order: Battery pack FRU. Memory slot cover FRU.
    • 2.Push down the keyboard a little and slide it toward the arrow 2 to detach the front edge of the keyboard from the frame.
    • 3.Lift the keyboard a little in the direction shown by arrow, and then detach the connector
  1. ThinkPad T420 Keyboard Replacement, Keyboard installation:: 手順 2、 1の画像 1
    • 1.Attach the keyboard connector.
    • 2.Attach the keyboard so that the keyboard edges are under the frame as shown in this figure.
    • 3.To make sure that the front edge of the keyboard is housed firmly, gently press the keys with your palms and slightly slide the keyboard toward you until it snaps into position.
    • 4.Make sure that the front edge of the keyboard is attached firmly.
    • 5.Secure the keyboard by tightening the screws from the bottom side of the computer.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Laptop
メンバー登録日: 05/29/18
1,021 ポイント
6のガイドは作成済み
1件のガイドコメント
I do not belive the first step has a picture. That would be very helpful. Thanks anyways.
Alexander Wiand - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 49
今までの合計 3,124
