メインコンテンツにスキップ
ThinkPad T420 Hard Drive Replacement
必要な工具と部品
  1. ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: 手順 1、 2の画像 1 ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: 手順 1、 2の画像 2
    • In most cases, it is better to reinstall the OS from scratch rather than image and restore. If the OS install is old, it is often overdue.
    • Before replacing the drive, backup your personal files. This can be done by hand, or automated.
  2. ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 手順 2、 3の画像 1 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 手順 2、 3の画像 2 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 手順 2、 3の画像 3
    • If the system is plugged in, disconnect it from power and remove the battery. Slide the lock tab to the unlocked position.
    • While holding the tab in place, remove the battery.
  3. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 手順 3、 3の画像 1 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 手順 3、 3の画像 2 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 手順 3、 3の画像 3
    • Remove the hard drive door from the system. Use a Phillips #1 bit.
    • Once the screw is loose, remove the drive cover as shown.
  4. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 手順 4、 3の画像 1 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 手順 4、 3の画像 2 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 手順 4、 3の画像 3
    • Pull the black tab on the drive caddy to remove the drive.
  5. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 手順 5、 3の画像 1 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 手順 5、 3の画像 2 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 手順 5、 3の画像 3
    • Remove the hard drive bumpers.
    • Remove the drive screws using a Phillips #1 screwdriver.
  6. ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: 手順 6、 2の画像 1 ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: 手順 6、 2の画像 2
    • Remove the old hard drive from the laptop. If you intend to keep it, store it in a antistatic bag if possible.
  7. ThinkPad T420 Hard Drive Replacement, Install the new hard drive: 手順 7、 2の画像 1 ThinkPad T420 Hard Drive Replacement, Install the new hard drive: 手順 7、 2の画像 2
    • If you are installing an SSD, a 7mm->9.5mm spacer may required.
    • Install your new drive using steps 6 through 3. Reinstall or reimage the operating system.
  8. ThinkPad T420 Hard Drive Replacement, Install the operating system: 手順 8、 1の画像 1
    • If you are installing Windows, use an official ISO or purchase OEM installation media without a product key.
    • In order to save time setting up your system in the future, reinstall Windows from scratch and image the computer once all the drivers and updates are installed.
    • After reassembling the system and confirming the new drive is recognized, reinstall your operating system.
終わりに
Once you install the new hard drive, reassemble your computer in reverse order. Once you do this, install an OS and restore your data.
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
88,851 ポイント
49のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,535のガイドは作成済み
3 件のコメント
Thank you for the meta notes
commander - 返信
Great instructions - you r doing a marvelous job - keep up the fine work !! God bless u !!!!
brixler jandley - 返信
Also - love the cat, I also am a cat fan big time !!!
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 109
今までの合計 22,742
