はじめに
If the hard drive in your ThinkPad T420 has failed or you wish to install a larger or faster drive, this guide will show you how to replace the hard drive.
Guide notes
- This guide does not cover operating system installation.
- I may be able to help locate an image if I know what you need, but there are no gaurantees.
- If you are installing an SSD or an thin Advanced Format (AF) drive, a 7mm->9.5mm drive spacer may be required. These are readily available online from sites like eBay if required.
- If you are installing a hard drive, cut the spacer based on the location of the breather hole. Heat kills spinning drives.
- ANY UNKNOWN HDP PASSWORDS MUST BE REMOVED BEFORE REPLACING THE DRIVE.
- This will transfer to your new drive since it is stored on the ATMEL chip.
- Make a backup of your original drive and image it, if possible. This is optional, but can be used to recover if something goes wrong.
- Note: Not recommended for used systems. Reinstall from scratch, and make a clean image from a fresh install.
- Once you are done with the old drive if you do not need it, securely erase it.
- Note: SED's (and FDE) can be erased by deleting the encryption key from the drive rather then a full drive erase.
必要なもの
Before replacing the drive, backup your personal files. This can be done by hand, or automated.
If the system is plugged in, disconnect it from power and remove the battery. Slide the lock tab to the unlocked position.
While holding the tab in place, remove the battery.
Remove the hard drive door from the system. Use a Phillips #1 bit.
Once the screw is loose, remove the drive cover as shown.
Remove the hard drive bumpers.
Remove the drive screws using a Phillips #1 screwdriver.
Remove the old hard drive from the laptop. If you intend to keep it, store it in a antistatic bag if possible.
Install your new drive using steps 6 through 3. Reinstall or reimage the operating system.
After reassembling the system and confirming the new drive is recognized, reinstall your operating system.
Once you install the new hard drive, reassemble your computer in reverse order. Once you do this, install an OS and restore your data.
4 の人々がこのガイドを完成させました。
3 件のコメント
Great instructions - you r doing a marvelous job - keep up the fine work !! God bless u !!!!
Also - love the cat, I also am a cat fan big time !!!
