メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ThinkPad Edge E31 RAM Replacement
必要な工具と部品
  1. ThinkPad Edge E31 RAM  Replacement, Battery: 手順 1、 1の画像 1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 RAM  Replacement: 手順 2、 1の画像 1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: 手順 3、 1の画像 1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
  4. ThinkPad Edge E31 RAM  Replacement, RAM: 手順 4、 1の画像 1
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
  5. ThinkPad Edge E31 RAM  Replacement: 手順 5、 1の画像 1
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
  6. ThinkPad Edge E31 RAM  Replacement: 手順 6、 1の画像 1
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
終わりに
作成者
2人の作成者と共同で作成されました。
Riley
メンバー登録日: 03/19/17
601 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team S6-G5, Isaacson Spring 2017 UMass Dartmouth, Team S6-G5, Isaacson Spring 2017人のメンバー
UMASSD-ISAACSON-S17S6G5
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 493
