メインコンテンツにスキップ
ThinkPad 13 Chromebook Display Replacement
必要な工具と部品
  1. ThinkPad 13 Chromebook Display Replacement, Lower Case: 手順 1、 2の画像 1 ThinkPad 13 Chromebook Display Replacement, Lower Case: 手順 1、 2の画像 2
    この手順で使用する道具:
    • Before proceeding, unplug and power down your ThinkPad. Close the display and lay it on a soft surface, top-side down.
    • Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
    • You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
  2. ThinkPad 13 Chromebook Display Replacement: 手順 2、 1の画像 1
    • Insert an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the case, pushing inward to release the clips securing the lower case. You should feel and hear the clip pop free.
  3. ThinkPad 13 Chromebook Display Replacement: 手順 3、 1の画像 1
    • When all the clips have been released, you should be able to easily remove the lower case.
    • If you feel resistance when lifting the case, ensure all the clips have been released and all the screws are adequately loosened.
  4. ThinkPad 13 Chromebook Display Replacement, Battery Connector: 手順 4、 1の画像 1
    • Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
  5. ThinkPad 13 Chromebook Display Replacement, Battery Screws: 手順 5、 1の画像 1
    • Remove the four screws securing the battery to the upper case.
  6. ThinkPad 13 Chromebook Display Replacement: 手順 6、 1の画像 1
    • Lift the battery out of the upper case.
  7. ThinkPad 13 Chromebook Display Replacement, Display Removal: 手順 7、 2の画像 1 ThinkPad 13 Chromebook Display Replacement, Display Removal: 手順 7、 2の画像 2
    • Before proceeding, unplug and power down your ThinkPad. Set your computer to face you, with the screen open.
    • Use the plastic opening tool to pull the panel forward and release it from the display assembly.
    • You may need a little help from your fingers for the thicker bottom bezel.
    • Be careful not to put pressure on the LCD itself, as it could damage the display.
  8. ThinkPad 13 Chromebook Display Replacement: 手順 8、 1の画像 1
    • Open the laptop completely to 180 degrees and lay it flat.
    • Remove the four screws that secure the LCD panel to the plastic. Do not confuse these for the screws securing the hinge to the display assembly.
  9. ThinkPad 13 Chromebook Display Replacement: 手順 9、 2の画像 1 ThinkPad 13 Chromebook Display Replacement: 手順 9、 2の画像 2
    • Carefully separate the LCD panel from the plastic cover. and lower the screen onto the keys.
  10. ThinkPad 13 Chromebook Display Replacement: 手順 10、 2の画像 1 ThinkPad 13 Chromebook Display Replacement: 手順 10、 2の画像 2
    • Peel off the sticker securing the display cable to the LCD panel.
    • Using the flat end of a spudger, lift the cable lock and gently remove the display cable from the LCD panel.
    • Be very gentle removing this cable, as it is quite delicate.
  11. ThinkPad 13 Chromebook Display Replacement: 手順 11、 1の画像 1
    • Remove the LCD panel.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Whitson Gordon
メンバー登録日: 02/23/14
586 ポイント
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 20
今までの合計 1,891
