メインコンテンツにスキップ
Themotop Combination Central Heating and Boiler Micro Switch Maintainence
  1. Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 1、 3の画像 1 Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 1、 3の画像 2 Themotop Combination Central Heating and Boiler Micro Switch Maintainence, Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 1、 3の画像 3
    • PROBLEM: faulty micro switch. FIX: Disconnect power mains!!! remove the switch, check the conductivity with a multimeter.
  2. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 2、 3の画像 1 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 2、 3の画像 2 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 2、 3の画像 3
    • FIX: Disconnect power mains!!! remove the switch, check the conductivity with a multimeter. if the switch is faulty remove the green seal and drip some contact cleaner (alcohol) into the switch. Check the conductivity again. Let it dry upside down in a hot dry place.
  3. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 3、 2の画像 1 Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 3、 2の画像 2
    • check the conductivity with a multimeter. if the switch is faulty remove the green seal and drip some alcohol into the switch. Check the conductivity again. Let it dry upside down in a hot dry place. Buy a new one if it's still bad.
  4. Themotop Combination Central Heating and Boiler Micro Switch Maintainence: 手順 4、 1の画像 1
    • Put it back, reconnect mains but keep an eye on the gas flame that might turn on without the switch is being pressed (if it is so the switch is not dry inside). Say thanks to me ( atosmaximus (at) gmail.com :-)
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
atos maximus
メンバー登録日: 10/06/13
510 ポイント
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 3,377
