メインコンテンツにスキップ
Logitech G910 Lights Replacement
必要な工具と部品
  1. Logitech G910 Lights Replacement, Lights: 手順 1、 1の画像 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: 手順 2、 1の画像 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
    doesn’t mention unscrewing the screws under the palmrest to remove the plastic under the palmrest to get at the back screws underneath
    Richard Baranski - 返信
  3. Logitech G910 Lights Replacement: 手順 3、 1の画像 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
    Step 2a: remove the 7 screws on the back of the keyboard towards the top (including 2 under the arx Dock)
    Step 2b: remove the 8 screws from the back of the wrist rest
    Step 2c: remove the back of the wrist rest
    Step 2d: I've already removed 15 screws as per this guide, but there are 6 more under the wrist rest, should these be removed?
    Step 2e: somehow remove the plastic trim that comprises the rest of the wrist rest and the keyboard surround. This is where I'm stuck, I can't remove this.
    This guide to disassembly basically is “step 1: just disassemble the keyboard”
    Andrew Wynn - 返信
  4. Logitech G910 Lights Replacement, Lift the film: 手順 4、 2の画像 1 Logitech G910 Lights Replacement, Lift the film: 手順 4、 2の画像 2
    • Gently lift up the plastic film in the top right corner.
終わりに
5 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Nasser
メンバー登録日: 01/23/18
214 ポイント
1ガイドが承認済み
チーム
3 件のコメント
So what do I do after I take apart my keyboard?
CuddlyZebesian - 返信
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 22
過去 30 日: 79
今までの合計 6,026
