メインコンテンツにスキップ
The Claw Case Replacement
必要な工具と部品
  1. The Claw Case Replacement, Top Cover: 手順 1、 1の画像 1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Case Replacement: 手順 2、 1の画像 1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Case Replacement: 手順 3、 1の画像 1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Case Replacement: 手順 4、 1の画像 1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Case Replacement: 手順 5、 1の画像 1
    • Remove the top cover of The Claw machine.
  6. The Claw Case Replacement: 手順 6、 2の画像 1 The Claw Case Replacement: 手順 6、 2の画像 2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Case Replacement: 手順 7、 1の画像 1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Case Replacement, Case: 手順 8、 1の画像 1
    • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
  9. The Claw Case Replacement: 手順 9、 1の画像 1
    • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
  10. The Claw Case Replacement: 手順 10、 1の画像 1
    • Gently remove the broken clear plastic case.
    • Remember how the case sat into the frame so that you can seat the new case in the same way.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alain Pierre
メンバー登録日: 03/22/16
1,188 ポイント
9のガイドは作成済み
チーム
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S4G8
3 メンバー
18のガイドは作成済み
コメント 1 件
where can i get the clear plastic panels
cristian2002 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,460
