はじめに
If you are experiencing trouble with the claw or it does not seem to be opening or closing properly, it is possible that the claw itself is broken or damaged. This requires the user to open the claw device in order to access the mechanical claw. Follow this easy guide in order to properly and easily replace your claw.
必要な工具と部品
Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
My claw machine has only one of the chains attached when I opened the box. The claw does not open because that chain is not attached.
Addition to the above comment. The open chain is not attached to the gear box.
2 の人々がこのガイドを完成させました。
6 件のコメント
Where do I buy a new grabber thing
The 1st joystick that moves the claw forward and back doesn’t work.
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
My chain fell off and I dont know how to fix
Porque la garra no sube ni baja +?
Pero a los lados si funciona!?
Gracias
