メインコンテンツにスキップ
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
必要な工具と部品
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: 手順 1、 1の画像 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 2、 1の画像 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 3、 2の画像 1 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 3、 2の画像 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: 手順 4、 1の画像 1
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 5、 1の画像 1
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 6、 2の画像 1 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 6、 2の画像 2
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 手順 7、 1の画像 1
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
終わりに
作成者
1人の作成者と共同作成されました。
Jacob
メンバー登録日: 01/25/17
601 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 657
