はじめに
In this guide we will show you how to replace the 5 way toggle switch on a Rock Band Beatles Hofner Bass.
必要な工具と部品
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
With a J1 Phillips screwdriver, remove the six 5mm on the cover.
Remove the cover.
もう少しです!
終わりに
