メインコンテンツにスキップ
The Beatles Rock Band Hofner Bass Fret Buttons Replacement
必要な工具と部品
  1. The Beatles Rock Band Hofner Bass Fret Buttons Replacement, Fret Buttons: 手順 1、 1の画像 1
    • Flip the guitar onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 2、 1の画像 1
    • Flip the guitar to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 3、 2の画像 1 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 3、 2の画像 2
    • Flip the guitar on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the guitar is now open.
  4. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 4、 1の画像 1
    • Using a J1 Phillips screwdriver, unscrew the 10mm screw at the base of the neck.
  5. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 5、 1の画像 1
    • Remove the head of the guitar, at the top of the neck. Do this by simply pulling on it, it should slide off out fairly easily.
  6. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 6、 1の画像 1
    • Use a J1 Phillips screwdriver to remove three silver 10mm screws at the top of the neck.
  7. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 7、 1の画像 1
    • Pop off the red button at the top by prying.
    • Use a J1 Phillips screwdriver to remove the 10mm screw underneath.
  8. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 8、 2の画像 1 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 手順 8、 2の画像 2
    • Remove the 10mm screw on the fret buttons with a J1 Phillips screwdriver.
    • Remove the fret buttons.
終わりに
作成者
1人の作成者と共同作成されました。
Jacob
メンバー登録日: 01/25/17
601 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,332
