メインコンテンツにスキップ
The Beatles Rock Band Hofner Bass Directional Pad Replacement
必要な工具と部品
  1. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Back Plate: 手順 1、 1の画像 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 手順 2、 1の画像 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 手順 3、 2の画像 1 The Beatles Rock Band Hofner Bass Directional Pad Replacement: 手順 3、 2の画像 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: 手順 4、 2の画像 1 The Beatles Rock Band Hofner Bass Directional Pad Replacement, Directional Pad: 手順 4、 2の画像 2
    • Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
  5. The Beatles Rock Band Hofner Bass Directional Pad Replacement: 手順 5、 1の画像 1
    • Remove the directional pad button,
終わりに
作成者
1人の作成者と共同作成されました。
Jacob
メンバー登録日: 01/25/17
601 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G4
3 メンバー
6のガイドは作成済み
コメント 1 件
I need help re-assembling the Effect Switch. I have a tiny spring and steel ball that I don't know how to put back together.
Jay Kap - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 350
