メインコンテンツにスキップ
The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide
必要な工具と部品
  1. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide, The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 1、 1の画像 1
    • Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
  2. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 2、 1の画像 1
    • To remove the buttons, lift the "rubber button pad'' from the key fob shell.
  3. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 3、 1の画像 1
    • Remove the old CR2032 battery by simply pulling it out and replace it with a new one.
  4. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 4、 1の画像 1
    • Insert rubber button pad over the battery. Place the front end of the key fob over the buttons and press down until you hear a "click".
  5. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 5、 1の画像 1
    • Press the vehicle lock button to ensure all doors of the vehicle are locked.
  6. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 6、 1の画像 1
    • Insert key into the ignition.
  7. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 7、 1の画像 1
    • Press and hold the unlock button on the driver side door. Do not release until prompted to do so in Step 10.
    • Swiftly turn the ignition ON and OFF.
  8. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 9、 1の画像 1
    • Release the unlock button on the driver side door. You should hear the vehicle automatically lock and then unlock.
  9. The 2006 Chevy Silverado Key Fob Battery Replacement and Programming Guide: 手順 10、 1の画像 1
    • Press the lock and unlock buttons on the key fob simultaneously until the vehicle automatically locks and unlocks (This can take approx. 30 secs.)
    • Turn ignition on to exit programming mode.
    • Turn vehicle off and remove key.
    • Test key fob by pressing the lock/unlock buttons to ensure functionality.
終わりに
作成者
1人の作成者と共同作成されました。
Tiara Bailey
メンバー登録日: 02/03/20
217 ポイント
1ガイドが承認済み
チーム
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020人のメンバー
USFSM-STEWART-S20S1G1
23 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 35
今までの合計 3,467
