この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In this guide we will be replacing the backup battery for the TI-92.
必要な工具と部品
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Using a #00 Philip Screwdriver remove the 19mm screw located near the center of the back of the calculator on the panel with words "Test Access"
2 の人々がこのガイドを完成させました。
