メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Texas Instruments TI-92 Back Case Disassembly
必要な工具と部品
  1. Texas Instruments TI-92 Back Case Disassembly, Back Cover: 手順 1、 3の画像 1 Texas Instruments TI-92 Back Case Disassembly, Back Cover: 手順 1、 3の画像 2 Texas Instruments TI-92 Back Case Disassembly, Back Cover: 手順 1、 3の画像 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Back Case Disassembly: 手順 2、 2の画像 1 Texas Instruments TI-92 Back Case Disassembly: 手順 2、 2の画像 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Back Case Disassembly: 手順 3、 2の画像 1 Texas Instruments TI-92 Back Case Disassembly: 手順 3、 2の画像 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Back Case Disassembly, Batteries: 手順 4、 3の画像 1 Texas Instruments TI-92 Back Case Disassembly, Batteries: 手順 4、 3の画像 2 Texas Instruments TI-92 Back Case Disassembly, Batteries: 手順 4、 3の画像 3
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
  5. Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 手順 5、 3の画像 1 Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 手順 5、 3の画像 2 Texas Instruments TI-92 Back Case Disassembly, Texas Instruments TI-92 Back Case Disassembly: 手順 5、 3の画像 3
    • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
  6. Texas Instruments TI-92 Back Case Disassembly: 手順 6、 1の画像 1
    • Unscrew the 19mm screw located near center of the back of the calculator.
    • Remove the panel being held by the screw.
  7. Texas Instruments TI-92 Back Case Disassembly: 手順 7、 1の画像 1
    • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
  8. Texas Instruments TI-92 Back Case Disassembly: 手順 8、 2の画像 1 Texas Instruments TI-92 Back Case Disassembly: 手順 8、 2の画像 2
    • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
    • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
  9. Texas Instruments TI-92 Back Case Disassembly: 手順 9、 2の画像 1 Texas Instruments TI-92 Back Case Disassembly: 手順 9、 2の画像 2
    • Pull out the rectangular module when it is finally loose enough.
  10. Texas Instruments TI-92 Back Case Disassembly: 手順 10、 2の画像 1 Texas Instruments TI-92 Back Case Disassembly: 手順 10、 2の画像 2
    • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
    • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
終わりに
作成者
6人の作成者と共同で作成されました。
Daniel Maldonado
メンバー登録日: 04/14/10
264 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S15G51
5 メンバー
9のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 32
過去 30 日: 92
今までの合計 2,611
