はじめに
If your screen Or motherboard is broken this guide is for you. The screen is tethered to the motherboard, so both items must be replaced at the same time.
  1. Remove the battery cover. Remove the AAA batteries from the calculator.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Use plastic opening tool to remove the backup battery.  Place the tool in the small cut-out next to the battery and pry the battery out.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  6. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  7. Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out. Remove the eight (8) 5mm Philips #00  screws on the motherboard.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  8. Carefully remove the motherboard and screen.  Grab the board by its side with one hand and the screen with the other.  Carefully lift the two parts up. Keep the face-plate face-down to prevent the keys from falling out.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
まとめ
16 の人々がこのガイドを完成させました。
Kevin
メンバー登録日: 2012年10月02日
374 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S18G37
5 メンバー
5のガイドは作成済み
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - 返信
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - 返信
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
統計データを表示:
過去 24時間: 15
過去 7 日: 81
過去 30 日: 336
今までの合計 39,814
