メインコンテンツにスキップ
Texas Instruments TI-83 Plus Individual Keys Replacement
必要な工具と部品
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 手順 1、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 手順 1、 2の画像 2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 2、 1の画像 1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 3、 1の画像 1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: 手順 4、 1の画像 1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 5、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 5、 2の画像 2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 手順 6、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 手順 6、 2の画像 2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 7、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 7、 2の画像 2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 手順 8、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 手順 8、 2の画像 2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: 手順 9、 1の画像 1
    • Clean the contacts on the keyboard with a soft cloth.
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 手順 10、 2の画像 1 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 手順 10、 2の画像 2
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jared
メンバー登録日: 10/02/12
135 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S18G37
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 18
今までの合計 4,560
