メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのTexas Instruments TI-82を修理する際は、iFixitの修理ガイドをご利用ください。
  1. Texas Instruments TI-82 Teardown, Texas Instruments TI-82 Teardown: 手順 1、 1の画像 1
    • The calculator comes with a matching protective shield which slides down over the front; when the calculator is in use, you can slide it over the back. This is a nice touch, as it makes the cover much more difficult to lose.
  2. Texas Instruments TI-82 Teardown: 手順 2、 3の画像 1 Texas Instruments TI-82 Teardown: 手順 2、 3の画像 2 Texas Instruments TI-82 Teardown: 手順 2、 3の画像 3
    • Flip the device over to access the battery cover.
    • Using a spudger, pry the release tab down and then pull the battery door up and off the calculator.
    • Remove:
    • 2 7.2mm Phillips #0 screws
    • 1 15.3mm Phillips #0 screw, and a battery retaining clip.
    • The CR1616 coin cell battery preserves settings and programs in memory while the main batteries are being changed.
  3. Texas Instruments TI-82 Teardown: 手順 3、 1の画像 1
    • Insert a spudger into the seam between the two halves of the case, and pry it apart.
    • Watch out for corrosion in older calculators around the battery terminals -- this is why you should never leave batteries in electronics for extended periods of time.
  4. Texas Instruments TI-82 Teardown: 手順 4、 1の画像 1
    • Opening the two halves of the calculator reveals a foil shield over the rest of the electronics.
    • Remove four Phillips screws to access the electronics underneath, then pull the shield away.
  5. Texas Instruments TI-82 Teardown: 手順 5、 1の画像 1
    • ... And, here's the guts of the thing.
    • SRM20255LLM10 / F4ZM1938 (32Kbyte SRAM)
    • LH531GP4 (Mask ROM)
    • T 84C00AM-8 (Z80 CPU)
    • Toshiba / TC14L010AF / 1273 9506EAI (ASIC)
  6. Texas Instruments TI-82 Teardown: 手順 6、 2の画像 1 Texas Instruments TI-82 Teardown: 手順 6、 2の画像 2
    • Remove the remaining Phillips screws.
    • The screen and main board will lift out, leaving the membrane keypad in the front case.
bushing
メンバー登録日: 04/23/10
10,250 ポイント
13のガイドは作成済み
コメント 1 件
Minor correction, the RAM part is SRM20256LLM10, a CMOS 256 kilobit (32x8) 100ns static RAM in 28 pin SOP form factor.
Nick M - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 88
今までの合計 20,593
