メインコンテンツにスキップ
Texas Instruments TI-80 Motherboard and Screen Replacement
必要な工具と部品
  1. Texas Instruments TI-80 Motherboard and Screen Replacement, Batteries: 手順 1、 1の画像 1
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Motherboard and Screen Replacement: 手順 2、 1の画像 1
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 手順 3、 3の画像 1 Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 手順 3、 3の画像 2 Texas Instruments TI-80 Motherboard and Screen Replacement, Back Case: 手順 3、 3の画像 3
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
  4. Texas Instruments TI-80 Motherboard and Screen Replacement, Motherboard and Screen: 手順 4、 2の画像 1 Texas Instruments TI-80 Motherboard and Screen Replacement, Motherboard and Screen: 手順 4、 2の画像 2
    • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
    • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
    • Using the blue plastic opening tool, pry the Motherboard up.
    • Using the blue plastic opening tool, pry up the screen from the screen mount.
終わりに
作成者
5人の作成者と共同で作成されました。
brian decater
メンバー登録日: 01/13/15
301 ポイント
3のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 587
