メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Texas Instruments TI-30Xa Battery Replacement
必要な工具と部品
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: 手順 1、 1の画像 1
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: 手順 2、 2の画像 1 Texas Instruments TI-30Xa Battery Replacement: 手順 2、 2の画像 2
    • Locate the six screws on the back of the calculator.
    • With a Phillips #1 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: 手順 3、 3の画像 1 Texas Instruments TI-30Xa Battery Replacement: 手順 3、 3の画像 2 Texas Instruments TI-30Xa Battery Replacement: 手順 3、 3の画像 3
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: 手順 4、 1の画像 1
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: 手順 5、 2の画像 1 Texas Instruments TI-30Xa Battery Replacement: 手順 5、 2の画像 2
    • The two LR44 batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
終わりに
55 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Chris L
メンバー登録日: 12/17/14
1,522 ポイント
3のガイドは作成済み
30 件のコメント
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
Scott Julien - 返信
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Dewellah - 返信
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
lasharlavenue - 返信
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
Esther Reese - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 109
過去 30 日: 600
今までの合計 114,002
