メインコンテンツにスキップ
Testing the Starbucks Barista Heating Element
必要な工具と部品
  1. Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: 手順 1、 2の画像 1 Testing the Starbucks Barista Heating Element, Testing the Starbucks Barista Heating Element: 手順 1、 2の画像 2
    • Remove the 6 Phillips #1 screws from the back panel.
    • Remove the back panel.
  2. Testing the Starbucks Barista Heating Element: 手順 2、 1の画像 1
    • Make sure the machine is turned off and unplugged.
    • Set your voltmeter in continuity mode and place the leads on the two 90 degree prongs on the boiler's heating element.
    • It does not matter which lead touches which prong as you're just testing for a break, or "open" in the heating element circuit.'''
    • If the voltmeter shows 0, or "open", then there is an issue with the heating element's continuity and it needs to be replaced.
    • If given a reading, then your heating element is fine.
  3. Testing the Starbucks Barista Heating Element: 手順 3、 1の画像 1
    • In the water reservoir, place mixture of de-calcifying agent and water as directed on the product label.
    • Place a cup, to catch fluid, underneath the portafilter.
    • Run Barista, as if making coffee, for the amount of time directed by the de-calcifying product.
    • See the links section of the device page for further directions.
    Consider adding a step to remove the slide on wire connectors to the heater terminals before testing.
    laryball - 返信
終わりに
11 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Brian McMurray
メンバー登録日: 01/31/11
213 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G42
4 メンバー
5のガイドは作成済み
6 件のコメント
I did this a few months ago and the boiler was full of rusty gunk. This guide sure did help me out.
oguitar200 - 返信
the same here - it was disgusting... was afraid to have damaged it while cleaning it. tested it yesterday already... just going through all the steps to validate function of the units.
Martin Zeitler -
hi ! we have Starbucks Barisa Milano. some how it didnt want switch on! my husband wanted to have a look but we cant open. do you gave any guidence?
Zorigoo Purev - 返信
I have a Barista and want to change the pressure washer of the coffee maker arm.
can any one help me?
sonnynima - 返信
I feel the temperature of the espressos i’m making is not hot enough. How do i raise the thermostat to activate the Ready light at a higher temp?
Tim Furnish - 返信
The Barista doesn't have a way to adjust the brew temp. But, if you preheat the portafilter and your cup (by running an empty shot of hot water) that will help you make the best of the situation. And, the target temp for espresso brewing is not 212- it's about 190-195 degrees.
Phil Van Kirk -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 20,620
