メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Testing Power Cord Continuity
必要な工具と部品
  1. Testing Power Cord Continuity, Set the multimeter to continuity test mode: 手順 1、 2の画像 1 Testing Power Cord Continuity, Set the multimeter to continuity test mode: 手順 1、 2の画像 2
    • Unplug the power cord from the device and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a diode or sound wave symbol as seen in the pictures. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
    FixBotに聞いてみる
  2. Testing Power Cord Continuity, Test for a break in the cable: 手順 2、 1の画像 1
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will continuously beep. A short beep does not mean that there is continuity. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
    FixBotに聞いてみる
  3. Testing Power Cord Continuity, Test for a short: 手順 3、 1の画像 1
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
    FixBotに聞いてみる
ゴール
161 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Darren Chan
メンバー登録日: 10/28/09
5,388 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009人のメンバー
CPSU-REGAN-F09S5G1
5 メンバー
23のガイドは作成済み
16件のガイドコメント
Thank you very much.
Kaky Jerry - 返信 共有
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Muhammad Imran - 返信 共有
Brilliant love it
Liam Breen - 返信 共有
Worked like a charm I feelik an electrician
hadpaulkh - 返信 共有
I found this really wonderful and useful with details explained very well. I was always wondering what the electricians do with a multimeter. Now iI would buy one multimeter and do this on my own. Great and cool guide. Write more guides for other tests and verification.
Avinash S - 返信 共有
コメントを追加
統計データ:
過去 24時間: 30
過去 7 日: 228
過去 30 日: 1,756
今までの合計 280,815
