メインコンテンツにスキップ
Tesla Model S Key Fob Battery Replacement
必要な工具と部品
  1. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: 手順 1、 3の画像 1 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: 手順 1、 3の画像 2 Tesla Model S Key Fob Battery Replacement, Key Fob Battery: 手順 1、 3の画像 3
    • Remove the protective case from the key fob.
    • This step is optional; not everyone has a protective case.
  2. Tesla Model S Key Fob Battery Replacement: 手順 2、 3の画像 1 Tesla Model S Key Fob Battery Replacement: 手順 2、 3の画像 2 Tesla Model S Key Fob Battery Replacement: 手順 2、 3の画像 3
    • Insert the flat end of a spudger into the notch, and gently pry the key fob open along the seam.
    • Separate the cover from the key fob.
  3. Tesla Model S Key Fob Battery Replacement: 手順 3、 3の画像 1 Tesla Model S Key Fob Battery Replacement: 手順 3、 3の画像 2 Tesla Model S Key Fob Battery Replacement: 手順 3、 3の画像 3
    • Insert the flat end of a spudger into the entry point at the top of the key fob.
    • Lightly push the spudger under the battery.
    • Remove the battery from the key fob.
  4. Tesla Model S Key Fob Battery Replacement: 手順 4、 3の画像 1 Tesla Model S Key Fob Battery Replacement: 手順 4、 3の画像 2 Tesla Model S Key Fob Battery Replacement: 手順 4、 3の画像 3
    • With your fingers, insert a new CR2032 battery into the opening.
    • Ensure correct placement of the battery by having the writing facing up toward you and the blank side with a number facing down inside the battery opening.
    • Push the battery with your thumb to lock it into place.
  5. Tesla Model S Key Fob Battery Replacement: 手順 5、 3の画像 1 Tesla Model S Key Fob Battery Replacement: 手順 5、 3の画像 2 Tesla Model S Key Fob Battery Replacement: 手順 5、 3の画像 3
    • To close the key fob, enter the wider side of the cover into the opening in the middle of the key fob.
    • You should see the end of the cover a little popped out.
    • With your thumb and pointer finger push together the cover and the key fob to allow for the key fob to be securely closed.
  6. Tesla Model S Key Fob Battery Replacement: 手順 6、 3の画像 1 Tesla Model S Key Fob Battery Replacement: 手順 6、 3の画像 2 Tesla Model S Key Fob Battery Replacement: 手順 6、 3の画像 3
    • This step is optional (not everyone has a case).
    • Place the key fob into the opening of the case.
ゴール
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Stefanie Ayala
メンバー登録日: 03/19/22
175 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 4-3, Briggs Spring 2022 CSU Los Angeles, Team 4-3, Briggs Spring 2022人のメンバー
CSULA-BRIGGS-S22S4G3
1 メンバー
1のガイドは作成済み
コメント 1 件
Really, that tip was helpful, the last time i my model s tesla key fob's battery was dead, I order another on amazon, and some tips online here on tesla key fob programming. At first, I was a little bit skeptical given that I have not done such a thing before on my tesla. However, the process was really simple and the guide on the site was helpful.
Ayo Idowu - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 19
過去 30 日: 77
今までの合計 4,965
