メインコンテンツにスキップ
Tennis Racquet Grip Tape Replacement
必要な工具と部品
  1. Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: 手順 1、 2の画像 1 Tennis Racquet Grip Tape Replacement, Tennis Racket Grip Tape: 手順 1、 2の画像 2
    • Pull the rubber collar towards the tennis racquet head off the handle.
  2. Tennis Racquet Grip Tape Replacement: 手順 2、 1の画像 1
    • Unwrap the tape on the tennis racquet handle top.
  3. Tennis Racquet Grip Tape Replacement: 手順 3、 3の画像 1 Tennis Racquet Grip Tape Replacement: 手順 3、 3の画像 2 Tennis Racquet Grip Tape Replacement: 手順 3、 3の画像 3
    • Remove the old grip.
    • Some older tennis racquets may have a few staples holding the grip to the buttcap. Use the staple remover to take them out.
  4. Tennis Racquet Grip Tape Replacement: 手順 4、 1の画像 1
    • Peel off 6 inches of the paper backing covering the adhesive from the replacement grip.
  5. Tennis Racquet Grip Tape Replacement: 手順 5、 2の画像 1 Tennis Racquet Grip Tape Replacement: 手順 5、 2の画像 2
    • Face the racquet so the buttcap is towards you.
    • If you are left-handed, wrap the tape towards the right. This method is what is used in the photos.
    • If you are right-handed, wrap the tape towards the left
    • Wrap the grip flush with the buttcap base.
  6. Tennis Racquet Grip Tape Replacement: 手順 6、 2の画像 1 Tennis Racquet Grip Tape Replacement: 手順 6、 2の画像 2
    • Wrap the handle at a steady incline, peeling off the backing 6 inches at a time.
    • Stop wrapping just before you finish wrapping the handle.
    • The handle is the off color or unpainted portion below the tennis racquet head.
  7. Tennis Racquet Grip Tape Replacement: 手順 7、 2の画像 1 Tennis Racquet Grip Tape Replacement: 手順 7、 2の画像 2
    • Wrap the handle top with the backing on.
    • Mark a horizontal line parallel to the buttcap around the grip.
  8. Tennis Racquet Grip Tape Replacement: 手順 8、 1の画像 1
    • Cut along the marked line using either scissors or a knife.
    • Cutting with scissors is significantly easier, however if you do not have scissors that can cut the grip, a knife will work.
  9. Tennis Racquet Grip Tape Replacement: 手順 9、 1の画像 1
    • Remove the backing and finish wrapping the replacement grip.
  10. Tennis Racquet Grip Tape Replacement: 手順 10、 1の画像 1
    • Wrap the tape that comes with the grip around the handle halfway on the racquet and halfway on the grip.
  11. Tennis Racquet Grip Tape Replacement: 手順 11、 2の画像 1 Tennis Racquet Grip Tape Replacement: 手順 11、 2の画像 2
    • Complete your fix by pulling the rubber collar back to its original location.
    • If you do not wish to add an overgrip, skip step 12.
  12. Tennis Racquet Grip Tape Replacement: 手順 12、 1の画像 1
    • Pull the collar up off the handle.
    • Repeat steps 4 - 11 to apply the overgrip.
終わりに
Congratulations, your racquet grip is now fixed and you can go out and continue playing!
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Aisleen Santos
メンバー登録日: 04/28/17
196 ポイント
1ガイドが承認済み
チーム
UC Davis, Team S3-G1, Coad Spring 2017 UC Davis, Team S3-G1, Coad Spring 2017人のメンバー
UCD-COAD-S17S3G1
3 メンバー
2のガイドは作成済み
4 件のコメント
Thank you I’ve found particularly useful the, then obvious when you think about it, comment that left handed setup is different to the right handed one!
Sam Curti - 返信
now this was helpfull, What's the difference between Eastern grip and Continental grip? Are they basically the same grip?
JACKSON RYAN - 返信
This guide about tennis grip was worth reading and helped to develop my skills to the next level.
Tennis Unit - 返信
I use this tennis guide, it’s quite worthy.
Rondaromero - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 84
今までの合計 18,473
