メインコンテンツにスキップ
Telikin Elite Silver 22in Touchscreen Computer
必要な工具と部品
  1. Telikin Elite Silver 22in Touchscreen Computer, Front glass removal: 手順 1、 1の画像 1
    • Lay the computer down on a flat surface
    • Put your suction cups on the top corners of the screen
    • Pull upwards in an arching motion trying to pull the front glass towards yourself. It's held in place with magnets, some force may be required.
  2. Telikin Elite Silver 22in Touchscreen Computer, Front glass ribbon cable removal: 手順 2、 1の画像 1
    • Disconnect the ribbon cables.
    • While wearing gloves remove the front glass and place it to the side
  3. Telikin Elite Silver 22in Touchscreen Computer, Screen bracket removal: 手順 3、 1の画像 1
    • Remove the brackets on the top corners of the screen using a Phillips head screwdriver, put aside for reassembly.
  4. Telikin Elite Silver 22in Touchscreen Computer, Moving the screen out of the way: 手順 4、 1の画像 1
    • Once the screen is unscrewed pull in a similar arching motion as you did the front glass.
  5. Telikin Elite Silver 22in Touchscreen Computer, Reasembily tips: 手順 5、 1の画像 1
    • When reassembling, ensure that the screen is flush with all four corners. Otherwise it will not seat back into the chassis properly.
  6. Telikin Elite Silver 22in Touchscreen Computer: 手順 6、 1の画像 1
    • This is the INCORRECT way to put the brackets back on, the bend point should be facing upwards
    • As some of the screws are next to the magnets, you may want to use a pair of pliers or tweezers to get them started in the holes
終わりに
作成者
1人の作成者と共同作成されました。
Frank_64
メンバー登録日: 09/12/25
283 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 32
今までの合計 72
