ツール
パーツ
The removal of the power switch is quite simple. First, open the case by removing all the screws on the rear panel marked with an arrow. (ATTENTION: different lengths and thickness! - when unscrewing remember which screw belongs where.
Then carefully lift off the back panel. Disconnect cables that prevent the rear panel from lifting off. Now, use a pair of needle nose pliers to squeeze the retaining clips that hold the switch in the TV housing and unclip the switch from the TV housing. (if necessary, use a flat screwdriver)
As already mentioned - connect the cable to the new switch and snap the snap-in switch back into the housing. Replace the back panel and screw in the screws again where they were screwed out.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
