メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Telecaster Guitar String(s) Replacement
必要な工具と部品
    1. Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 手順 1、 3の画像 1 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 手順 1、 3の画像 2 Telecaster Guitar String(s) Replacement, Unwind the Guitar Strings: 手順 1、 3の画像 3
      • Start with the low E string (the furthest on the right). Unwind the string by turning the tuning peg counter-clockwise.
      • Keep the string secure by placing one finger on the string's nut slot.
      • After unwinding the string, the segment coiled around the post will come loose. Pull the string out of the post.
      FixBotに聞いてみる
      コメントを追加
    2. Telecaster Guitar String(s) Replacement, Remove Old Strings: 手順 2、 3の画像 1 Telecaster Guitar String(s) Replacement, Remove Old Strings: 手順 2、 3の画像 2 Telecaster Guitar String(s) Replacement, Remove Old Strings: 手順 2、 3の画像 3
      • Uncoil the end of the string as much as possible.
      • Caution: Use caution in handling the ends of strings as they are extremely sharp.
      • Pull the end of the string through the bridge and out through the back of the guitar.
      FixBotに聞いてみる
      コメントを追加
    3. Telecaster Guitar String(s) Replacement, Insert New Strings: 手順 3、 3の画像 1 Telecaster Guitar String(s) Replacement, Insert New Strings: 手順 3、 3の画像 2 Telecaster Guitar String(s) Replacement, Insert New Strings: 手順 3、 3の画像 3
      • Insert the pointed end of the new string through the corresponding hole on the back of the guitar.
      • Turn the guitar over and pull the string all the way through.
      FixBotに聞いてみる
      コメントを追加
    4. Telecaster Guitar String(s) Replacement, Clip Excess String: 手順 4、 3の画像 1 Telecaster Guitar String(s) Replacement, Clip Excess String: 手順 4、 3の画像 2 Telecaster Guitar String(s) Replacement, Clip Excess String: 手順 4、 3の画像 3
      • There will be extraneous string length while replacing the 5th and 6th (furthest to the right) strings. Using a wire cutter, you may opt to trim the length of these strings.
      • Stretch out the replacement string and cut it about 3-4 peg lengths away from the peg of the string you're replacing. In this case, you are replacing the 5th string and will cut the string near the 2nd string peg.
      FixBotに聞いてみる
      コメントを追加
    5. Telecaster Guitar String(s) Replacement, Insert String into Peg: 手順 5、 3の画像 1 Telecaster Guitar String(s) Replacement, Insert String into Peg: 手順 5、 3の画像 2 Telecaster Guitar String(s) Replacement, Insert String into Peg: 手順 5、 3の画像 3
      • Insert the end of the cut string into the middle hole of the corresponding peg.
      • Keep pushing the end of the string to the bottom and bend the string until the outside segment touches the bottom of the guitar head.
      FixBotに聞いてみる
      コメントを追加
    6. Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 手順 6、 3の画像 1 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 手順 6、 3の画像 2 Telecaster Guitar String(s) Replacement, Tighten Strings & Tune Guitar: 手順 6、 3の画像 3
      • Pushing the end of the string to the bottom and the outside segment to the guitar head, turn the tuning peg clockwise.
      • When the string is tight enough, you may release it. Make sure the string fits securely within the nut slot.
      • Using a tuner of your choice, tighten the guitar string until it matches the correct pitch.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jasper
メンバー登録日: 04/11/21
214 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team S1-G17, Harris Spring 2021 CSU Los Angeles, Team S1-G17, Harris Spring 2021人のメンバー
CSULA-HARRIS-S21S1G17
1 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 94
今までの合計 10,824
