メインコンテンツにスキップ
Teenage Engineering OP-Z Function Key Plastic Buttons Replacement
必要な工具と部品
  1. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 手順 1、 3の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 手順 1、 3の画像 2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Back Cover: 手順 1、 3の画像 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 2、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 2、 2の画像 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 3、 1の画像 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Battery: 手順 4、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Battery: 手順 4、 2の画像 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 5、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 5、 2の画像 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Expansion Module: 手順 6、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Expansion Module: 手順 6、 2の画像 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 7、 1の画像 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Midframe: 手順 8、 1の画像 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 9、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 9、 2の画像 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 10、 3の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 10、 3の画像 2 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 10、 3の画像 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 11、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 11、 2の画像 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Function Key Plastic Buttons: 手順 12、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement, Function Key Plastic Buttons: 手順 12、 2の画像 2
    • Use a spudger to push the first set of function buttons inwards.
  13. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 13、 1の画像 1
    • Remove the first set of function buttons.
    • This pair has a circular alignment post between the buttons and a dot mark on one of the buttons.
  14. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 14、 2の画像 1 Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 14、 2の画像 2
    • Use a spudger to push the second set of function buttons inwards.
  15. Teenage Engineering OP-Z Function Key Plastic Buttons Replacement: 手順 15、 1の画像 1
    • Remove the second set of function buttons.
    • This pair has an elliptical alignment post between the buttons and a straight mark on one of the buttons.
終わりに
作成者
2人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
124,137 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,131のガイドは作成済み
コメント 1 件
Torx t4 screwdriver doesn’t work! Seems too big. Wasting too much money so far to fix something that shouldn’t have worn to breaking point so quickly. Gutted.
Sam Lsn - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 24
今までの合計 1,900
