メインコンテンツにスキップ
Teenage Engineering OP-1 Flex Cable Replacement
必要な工具と部品
  1. Teenage Engineering OP-1 Flex Cable Replacement, key removal: 手順 1、 3の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, key removal: 手順 1、 3の画像 2 Teenage Engineering OP-1 Flex Cable Replacement, key removal: 手順 1、 3の画像 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  2. Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: 手順 2、 2の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, removing scissors mechanisms: 手順 2、 2の画像 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  3. Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 手順 3、 3の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 手順 3、 3の画像 2 Teenage Engineering OP-1 Flex Cable Replacement, unscrew keyboard: 手順 3、 3の画像 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  4. Teenage Engineering OP-1 Flex Cable Replacement, unplug and remove keyboard: 手順 4、 1の画像 1
    • Unlock the flex cables by pushing the two black nibs on both sides of each connector.
    • Now you can pull the flex cables out and remove the keyboard completely.
  5. Teenage Engineering OP-1 Flex Cable Replacement, remove display: 手順 5、 3の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, remove display: 手順 5、 3の画像 2 Teenage Engineering OP-1 Flex Cable Replacement, remove display: 手順 5、 3の画像 3
    • Open the display cable connector by using a plastic opening tool to flip the latch upwards.
    • The display is held in place with a mild adhesive. A spudger helps you to get it free.
    • Now you can unplug the cable and take out the whole display.
  6. Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: 手順 6、 2の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, DSP Board: 手順 6、 2の画像 2
    • Disconnect the battery connector from the DSP board.
    • Unscrew the two Phillips #00 screws holding the board down.
  7. Teenage Engineering OP-1 Flex Cable Replacement: 手順 7、 2の画像 1 Teenage Engineering OP-1 Flex Cable Replacement: 手順 7、 2の画像 2
    • Now you can carefully lift the DSP board to access the flex cable connector underneath.
    • Disconnect the flex cable by using a spudger and remove the DSP board.
  8. Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: 手順 8、 2の画像 1 Teenage Engineering OP-1 Flex Cable Replacement, Flex Cable: 手順 8、 2の画像 2
    • Flip the OP-1 over to open the back panel giving you access to the connector board.
    • Disconnect the flex cable from the connector board.
  9. Teenage Engineering OP-1 Flex Cable Replacement: 手順 9、 2の画像 1 Teenage Engineering OP-1 Flex Cable Replacement: 手順 9、 2の画像 2
    • Returning to the front side you can unplug the flex cable from the UI board.
    • Now the flex cable is free and can be pulled out completely.
終わりに
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
112,847 ポイント
188のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
136 メンバー
15,131のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 39
今までの合計 4,138
