メインコンテンツにスキップ
Teddy Ruxpin Housing Cover Replacement
必要な工具と部品
  1. Teddy Ruxpin Housing Cover Replacement, Battery: 手順 1、 2の画像 1 Teddy Ruxpin Housing Cover Replacement, Battery: 手順 1、 2の画像 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Housing Cover Replacement: 手順 2、 1の画像 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Housing Cover Replacement: 手順 3、 1の画像 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Housing Cover Replacement, Arms: 手順 4、 3の画像 1 Teddy Ruxpin Housing Cover Replacement, Arms: 手順 4、 3の画像 2 Teddy Ruxpin Housing Cover Replacement, Arms: 手順 4、 3の画像 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Housing Cover Replacement: 手順 5、 1の画像 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Housing Cover Replacement: 手順 6、 3の画像 1 Teddy Ruxpin Housing Cover Replacement: 手順 6、 3の画像 2 Teddy Ruxpin Housing Cover Replacement: 手順 6、 3の画像 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Housing Cover Replacement: 手順 7、 2の画像 1 Teddy Ruxpin Housing Cover Replacement: 手順 7、 2の画像 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Housing Cover Replacement: 手順 8、 2の画像 1 Teddy Ruxpin Housing Cover Replacement: 手順 8、 2の画像 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Housing Cover Replacement: 手順 9、 1の画像 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Housing Cover Replacement, Housing Cover: 手順 10、 3の画像 1 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 手順 10、 3の画像 2 Teddy Ruxpin Housing Cover Replacement, Housing Cover: 手順 10、 3の画像 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jonny Brazil
メンバー登録日: 01/23/20
190 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S18-G5, White Winter 2020 Cal Poly, Team S18-G5, White Winter 2020人のメンバー
CPSU-WHITE-W20S18G5
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 480
