メインコンテンツにスキップ
はじめに
This device's power cord may break, so being able to easily replace it is important. This guide will teach you how to replace the rice cooker's power cord.
パーツ
パーツは指定されていません。
  1. Lift the lid and bowl from the top of the device.
    • Lift the lid and bowl from the top of the device.
    • Be sure device is not plugged in before beginning replacement of power cord.
  2. Turn device upside-down so that the three legs point upwards.
    • Turn device upside-down so that the three legs point upwards.
  3. Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
    • Remove the one 7mm Phillips Head #3 spanner screw from the side of the brass panel.
  4. Lift the brass plate from the device and set it aside.
    • Lift the brass plate from the device and set it aside.
  5. Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
    • Remove the 7mm Phillips #3 brass screw that connects the white power cord wire and blue wire closest to the power cord.
  6. Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
    • Remove the 10mm Phillips #3 brass screw above the heating element that connects the white power cord wire and the maroon wire.
  7. Using your hands, from the inside of the device,  push the black plastic wire holder to release cords.
    • Using your hands, from the inside of the device, push the black plastic wire holder to release cords.
  8. Pull the power cord through the hole, isolating the power cord from the device.
    • Pull the power cord through the hole, isolating the power cord from the device.
  9. Thread the new power cord wires into the hole.
    • Thread the new power cord wires into the hole.
    • To ensure the power cord is compatible with the device, make sure that the replacement cord you are using has a proper insulating coating and uses a NEMA 1 plug. NEMA 1 plugs are the common type of plug that have two parallel "|" shaped metal beams.
終わりに
ある他の人がこのガイドを完成しました。
Katy Weber
メンバー登録日: 2016年01月28日
134 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 1-6, Sydow campbell Spring 2016 University of Alabama, Team 1-6, Sydow campbell Spring 2016人のメンバー
UA-SYDOW CAMPBELL-S16S1G6
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 39
今までの合計 1,494
